GM 12 BOLT REAR END PROBLEMS Need Some Help Please
Discussion in 'The Garage' started by doctor4x4, Nov 24, 2003.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    anybody have a blown up view of one or a page that teaches ya how to set up the proper ring and pinion pattern
    here's what i got
    i bought the complete axle allready assembled but the guy must have set it up wrong as it growls at me when i take my foot off the gas but aceleration is fine no noise
    all parts are new well less then 100 miles on em
    4:10 carrier with thickset 4:56 gears
    and a Detroit Easy Locker
    thanks in advance
    Randy
  2. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Here's what I'd do.
    Pull the cover and check backlash in 3 or 4 places around the ring gear. Should be 8-12 thousanths. If this is OK then check gear pattern on the drive side of the teeth, if you don't have marking compound use some grease. Should be in the middle to the toe end (toward the ID) and in the middle of the tooth up and down (top and root of the tooth).
    I wouldn't think that a bearing would be making your growling, or it would do it all the time. Good luck -Mark
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Bad carrier bearings can exhibit these noises, but it seems unlikely if everything is new. I would guess the gears are set up wrong and that it is possible that this has caused the bearings to go bad /forums/images/graemlins/crazy.gif
  4. ZootownK5
    ZootownK5 Registered Member
    Mar 22, 2003
    29
    Missoula, MT
    i bought a 12b from a guy a while ago and it did the same thing. thought it was a bad pinion bearing, but ended up being a loose pinion nut. i rebuilt the whole thing anyway with lower gears and an lsd. mine exhibited the same symtoms as would a bad pinion bearing.
    Ryan /forums/images/graemlins/k5.gif
  5. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    its times like this when im very glad and gratfull im a member
    thanks guys
    if any body has a link to a break down of 1 to make sure who ever put it together did it right
    i would really appricate
    R
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    find one of those 63-82 GM truck service manuals, they will have all the 12 bolt diagrams and info in them, any of those years vans blazers burbs pickups 5 and 10 series 8.875" ring gear, i dont currentyl know of any 12 bolt exploded view diagram online for 12 bolt truck 8.875"
    someone here might have a scanner and could scan you a diagram or more out of a service manual, i have some but no scanner /forums/images/graemlins/frown.gif
    noise like that is going to be bearing or incorrect backlash settings, most likely pinion shim problem, or overtightened the pinion crush sleeve which brings pinion to far forward and away from ring gear causign backlash excessive
