GM 14 Bolt Drum Brake Job Re-assembly Q's
Discussion in 'The Garage' started by foxman, Jan 7, 2005.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    I thought I would just replace the shoes, but ended up stripping down to the backing plate including wheel cylinders.
    I need to know the torque specs/sequence, and what to do about loading the bearings with lube. Only a couple of drops of gear lube was lost when removing the axles.
    Do I pack these bearings with grease or just use gear oil and coat them pretty good?
    do I have to drain and refill the pig?
    The existing gear oil looks good, and I'm laying in the snow so, if I don't have to, that would be good.
    Thanks for any help on this
    Jeremy
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    the bearings are lubed by gear oil only... so you can clean any build-up off them, recoat and re-install. no grease required.
    as far as the drain and refill... im not sure. I wouldnt think its required... you can probably just refill and not worry about it, just change it when it comes due
