GM 205 rail grinding Q!
Discussion in 'The Garage' started by sageman, Sep 7, 2003.
  1. sageman
    sageman Registered Member
    Sep 27, 2002
    40
    Calgary, Alberta, Canada.
    Presently grinding my detents on the shift rail and I seem to be close but I can not get the 205 to shift into HIGH in the FRONT only. And it almost engages into REAR HIGH when I have it in FRONT LOW!
    So I figured I would stop before I remove to much off of one of the detents.
    So the big question is which detent needs to be ground?
    Thanks!
  2. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    Do a search for twin stick, I did and found some good posts on it with pics, and mesurements that worked good for me just the other day.
  3. sageman
    Sep 27, 2002
    40
    Its' all good now... just increased the length of the detent closest to the one end to .850 thousands of an inch and now I get high gear in the front output as well!!! /forums/images/graemlins/grin.gif
