GM 60 or HP60??
Discussion in 'The Garage' started by b454rat, Apr 3, 2006.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    OK, I have both axles to use. The GM is in my truck now, used it today, got stuck. Running the div 205 that is royally pissing me off. I originally got the HP to do the SAS in my 97, but the way things are going, don't know if I will ever do the swap. Thinking about just leaving it stock, for a driver and hauler. If I stay with the GM 60, I have a 400/205 sitting outside, just need to swap guts. If I go with the HP, then I will need to get a driver drop 205, figure out how to hook it to a 400. I can get a div. 205 out of a Ford, this way I wouldn't need to get new shafts. Also, I just bought to boggers for 15" rims. I could just swap outers. I could sell the GM 60 to get the other two boggers and wheels.....
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    go with the hp60.not many guys run them in the older chevy's so itd be more unique, plus it helps ur driveshafts a bunch, im jealous. for the right price ill buy that 32spline gm205 from you :)
    i think with the correct backspacing (2.5") you can run the ford calipers with 15's. if not then you could jsut swap the chevy parts onto it and use those brakes
  3. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I already have 15x12 wheels, with 3.5 b/s. Read somewhere that some calipers can be ground to clear some b/s, but each is different. I have the brakes, so I should just try and see. All the stuff on the HP is new, rotors, calipes, pads, etc. If I do go that route, then the 205 will be for sale, along with the GM 60.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well put me first in line for the 205 if you do! :)
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I call dibs on the gm 60... how much shipped to 31827.. Will you be wanting to sell it toward the end of the summer or what? PM details :bow:
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    OK, PM me so I have your s/n so i know who wants what. I never shipped a t-case, geussing could put it on a pallet and ship that way. I'll call my shipper and find out. For the axle, figure $200 shipped. I just shipped one to VA, and all the other ones that I shipped were $200, except one that went to WA state, that was $300. But just to give you a heads up on the axle, it might have Ford outers on it. Like I said in my last post, I just bougth boggers and 15" wheels, and the GM 60 is clearanced for 15s. So, inless I get lucky on the Ford brakes, i'll be keeping the GM outers. If I do this, it will be soon, I want to get this done. Getting the ball-n-chain soon, don't know how much time or money I'll have to do ANYTHING if she has her way....
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I would definetly go high pinion just for the drive line angle...keeps it out of the rocks a little better also.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Those high pinion are great for driveshafts. Makes you wonder why they made anything else.
  9. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Wish they came with passengerside drop,SLOWLY converting one I have with basic back yard tools and no sleeve!
  10. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I have a ford drivers drop 205 case I would sell you. :D Does that help confuse you anymore?
  11. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    When you finish, post up a "how to." Looks interesting.
  12. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    my buddy works for teraflex and makes every tera 60 you see and built another guy I know the same thing...took a ford center section and retubed it, man that thing was sweet.
  13. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Yeah,I am taking pictures as I go.Not sure when I will be able to get back to this until I can make up my mind on what springs I am going to use(caster angles)
    This is not that hard of a project if you put your mind to it but time consuming if you want to keep it low buck.
    I looked around the web for info and found the tube press fit of .006-.010 on pirate and fiqured man thats tight and its going to come out of there hard so I put some pretty heavy push points on there and got ready for battle.
    With alittle heat that thing came out of there so easy I felt like a fool for wasting so much time with all the temporary attachments:eek1: :doah:
  14. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'm really impressed. I was under the impression that re-tubing was extremely difficult. Can you just swap the sides, after accounting for caster?
  15. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    194
    Santa Maria, CA
    :eek1::eek1: Isn't that a little tight for a casting? I thought castings had a fairly loose press fit because the casting would crack if it had a tight press.
  16. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I have plenty of Ford 205s to choose from. Just a matter of getting them. Thanks tho :)
  17. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    id swap chevy stuff on from the knuckles out, the ford stuff is real weak;)
  18. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    That's what I'm gonna do. If I had 16s or 16.5s I would leave it, but spending a grand on TWO boggers and TWO rims, not going back now. I don't wheel very hard, so even the Ford stuff would survive my driving.
  19. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Basically yeah just swap sides without even removing your outter "C"s.if your using a 78-79 housing,if using a later HP you will need to do it differently because it has a really short/long offset.
  20. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    What yr/truck model did yours come from?
