GM A body 12 bolt.
Discussion in 'Parts & Trucks Wanted' started by COCHEV, Mar 27, 2005.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    my brother in law in Kansas is looking for a Gm A body 12 bolt rear for his 72 Olds Cutlass. 68-72 chevelle, cutlass, 442 or skylark rear ends will work. :thumb:
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    any coil type 12 bolt from 64-72 will bolt in. there were different width though. but only an inch different. The 70-72 monte carlo axel will work also. Just stay away from an odd ball OLDS 12 bolt. It uses a 12 bolt cover, but really only has a 10 bolt carrier. It is also hard to get parts for.
  3. Cheyenne
    Cheyenne Registered Member
    Oct 31, 2000
    9
    Brandon, Florida
    12 BOLT available
    I have a 71 or 72 El Camino I'm taking apart just for the frame. Rear axle is available. Dunno the ratio, but will check it out if you want.
