GM Code G80
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackson 88K5, Nov 28, 2000.
  1. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    I have the code G80, I understand it means Gov-lock could someone explain what this means?
    http://www.tjcommons.com/88K5/
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    "Gov-Lok" is the what GM called their factory option limited slip differential.
  3. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,791
    100
    Paducah, KY
    It's the Eaton Gov-Lok limited slip. "Posi" as some people like to say. It's not bad when you have stock sized tires up to about 33" tires. Much more than that or if you do serious 4x4ing, you'll be wanting a high end limited slip or a locker. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's[​IMG]
