GM Dana 70 dually rear... posi?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mountainexplorer, Nov 20, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Did GM put very many posi Dana 70 rears in their 1-tons?
    I just got one and as I was pushing it into the driveway, turning sharp, I noticed the inner tire breaking loose (not slipping, but turning on the pavement as fast as the outer wheel for a while)
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I don't know but my C30 76' dually had both duals spinning last time I got it in some soft ground.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've heard that a lot of D70's got the Powr-Lok, which is a very good differential. Its the next posi-trac device better than the Track Lock. Where the TL has just a 2 spider pinion, the PL has 4 which is the reason for the strength. Nothing wrong with these posi's as long as the proper lube (posi lube) is added with the regular 80-90 weigth oil. /forums/images/graemlins/thumb.gif
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Is it very easy to tell visually by pulling the cover while its still in the rig? What might I look for?
    Thanks.
  5. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    This is what a Power Lock will look like;
  6. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    allan
    if it is indeed a power lock which as stated above is like 90% locker, it is my understanding that you can swap it into a front 60. with a power lock front and a detroit rear you'll be good to go. i wonder if the 4.10 gear set will effect what gear set you can run in the 60?
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    How is that D70 Power lock going to fit into that 60 front????
