Gm/dodge Np-208 Fixed Yoke Parts*SOLD*
Discussion in 'Engine | Tranny | T-case' started by MEK5, Jan 9, 2007.
  1. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Dodge NP-208 fixed yoke conv. parts,includes everything to change your GM 208 to a fixed yoke except the yoke.
    I put this together a couple years ago for my plow truck but went to a 241 instead.
    No welding required,uses a threaded stud thru the case for the shift rod.
    You will be getting just the parts,not the complete case. $50. + shipping on 20lbs.
  2. patt107
    patt107 1/2 ton status
    May 15, 2005
    276
    north carolina/new york
    so minus the rear flange/yoke is there anythign that i would have to do to my case other than bolt this up? let me know i am very interested
    thanks
    pat
  3. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    You will need to swap out the main shaft in your GM208 to this one and use this back half.You can use any of the 32spline transfer yokes with a 1 7/8" seal surface or turn down a 2 1/8" ss yoke to the smaller size.
    Heres some pics of it assembled: GM front-Dodge back
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Why the threaded rod for the shift rod?
    I just did this last week and the rods are the same, didn't have to do anything special.
    The only difference I had was the Dodge case has a different support for the side so it doesn't have a hole for the big bolt to bolt the support rod on the back half, it will only be bolted on the front half.
    Did I miss anything with the shift rod?
  5. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The rod support bung is in the wrong place on the Dodge back half,usually you weld another on.This bung is not welded and everything is sandwiched together and cannot move but still preload the spring.
  6. patt107
    May 15, 2005
    276
    Im interested in it, can you get me a shipping quote to 10940?
    thanks
    pat
  7. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Shipping is $14.00 Total $64.00
    I take PayPal
  8. patt107
    May 15, 2005
    276
    Whats your paypal address? this will work on a 700r4 right? you guys gotta stop selling things i want!!:D im going broke over here lol
    thanks
    pat
  9. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    PM sent
    Yes it will work with a 700R 208.
  10. patt107
    May 15, 2005
    276
    the money was sent. THIS IS NOW MINE!!:D
    thanks
    pat
