GM Driveshafts
Discussion in 'Suspension | Axle' started by kennyw, Mar 4, 2007.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    deleted
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    im interested in the 3/4 ton drive shaft...did you move your rear axle back any with this shaft???im gonna run 64s in the rear and only moving the rear shackle...is the shaft long enough???i need a set of u bolts too but i think im just gonna buy new ones...
  3. kennyw
    Jun 9, 2002
    13,223
    94
    It was built for a K5 with 2" lift 52" long springs. Axle was pretty much in stock location for this one.
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    What would shipping be on the sliders to 36092?
    Thanks,
    Mike
  5. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    pm sent
  6. kennyw
    Jun 9, 2002
    13,223
    94
    700R4/NP208 driveshaft is 30.5" collapsed and close to 32-32.5" extended.
    TH400/NP208 driveshaft is 31.5" collapsed and close to 33-33.5" extended.
  7. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    Hopefully someone can verify this but the 208 and the 241 are the same dimensions, right? If so I'd like the 400/208 front shaft.
  8. kennyw
    Jun 9, 2002
    13,223
    94
    I'm not sure on that. Feel free to do some checking but shipping should be around $15
  9. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    [​IMG][/QUOTE]
    What is the length of the top shaft? Are the joints 1350 size?
  10. kennyw
    Jun 9, 2002
    13,223
    94
    I'll have to double check the length. Tcase end is 1350, axle end is a 1310 to 1350 conversion joint (1350 on the axle, 1310 on the shaft).
