GM hydraulic clutch problems
Discussion in 'The Garage' started by JK5, Sep 8, 2006.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    On my 86 K30..465/205
    I have little or no clutch when I first start the rig up. After warming up,
    I have a good pedal. I have low fluids and I'm not sure what fluid it requires,
    power steering fluid???
    Thanks for your help.
  2. Zopilote
    Zopilote Registered Member
    Aug 28, 2006
    7
    -282
    My 85 K20 Suburban takes DOT 3 brake fluid in the clutch reservoir. I suspect yours is the same.
  3. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    I've had a couple vehicles in the past that acted similar. The next time you start it, pump the clutch 10-15 times & see if the pedal "raises."
    Roy
  4. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    The fluid is dot 3 brake fluid. I have had this problem before and u either have air getting in some where or needs to be bleed.
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Thanks for the replies...
    I filled the resevoir...all is well.
    I'm not sure if it's leaking or not...
    I've had the truck for 2 years, this is the first time I checked the level.:doah:
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    my ranger does that no sign of any leak but i have had to fill it twice in 5 years of owning it
