GM Jeep Flat Tops whats the differance?
Discussion in 'The Garage' started by CHEVY 4WD, Feb 24, 2006.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I need some knuckles to do crossover on my 10B and I found some on e-bay the guy said here GM/Jeep knuckles and I dont want any jeep parts... is there anyway to tell the differace? They have already been milled drilled and tapped and the casting # on the passenger side is C36519
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Full size jeeps used the full size d44 like chevy ford and dodge. The Full size (wagoneer i think) is the exact same knuckle on the chevys. EVERYTHING bolts up.
    This is a good link for flat top stuff. http://77cj.littlekeylime.com/flatop_knucles.html
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Good read , so how many have ever actually seen the pass side flattop drilled and tapped from the factory :ears:
    from that article :
    Dana never made a passenger side knuckle that was drilled and tapped from the factory. This is a general misconception that the above knuckle disproves. They are very rare but they are out there, so keep your eyes open. So far I only know of one other knuckle other then the one I found. Stamped # RC38618
  4. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Just a word of caution for others looking at this. Jeep also used a non-flat top knuckle on some of the full size D44s. It looks similar to the GM 10B one.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am using a Jeep D44 knuckle for my crossover steering. It works fine. The only thing that I have found that is different is that the spindle bolts are not in the exact same place and the caliper is moved a little bit upward. It has not caused any problems sofar.
    Harley
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I have a chevy 10 bolt knuckle with a WFO steering arm and 7 month old ball joints in it I'll be selling when I put my D60 underneath my truck in a couple weeks.
    Email me if intersted.
    Thanks,
