gm part # for 10B spindle & hub
Discussion in 'The Garage' started by mini_mull, May 31, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Anyone have the part numbers for the spindle and hub for a 10B front? It's off an '87 V10 Burb, even though that shouldn't matter. The dealership parts guy could only find the whole assembly knuckle out or the hub/rotor assembly, nothing listed separately. $$$ :frown1: Please help.
  2. dyeager535
    26,978
    I might have it linked on my parts page, no time to check it now, respond if you can't find a post with the link in it.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Time to hit the junkyards.
    I can pick up a spindle and axle shaft for around $15 at a u-pull-it type j/y.
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    PM Sent.
  5. goldwing2000
    goldwing2000 Guest
    I'll sell ya one (or two) off my '89 Blaze for next to nuthin'. :D
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    464039-spindle
    18027848-hub Only
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Mini_mull, once you've got the numbers you might want to check www.gmpartsdirect.com for a price (w/ freight). Typically they are cheaper and, if your dealer has to order the parts, the delivery time may be the same.
  8. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    Are you sure 464039 is just for the spindle? According here it is a kit that includes a seal bearing and race.
    http://www.gmpartsgiant.com/components/1985-gmc-k1500~2-axle-asm-front-tk061100106-l05m64k10903.html
    Also is this spindle the first or second design?
    Small-Bearing Spindle-Inner-Bearing Journal Size: 1.78"
    Stub Axle Spindle Bearing Kit Part# BRGBK1 $15.99
    Hub Lock Nut Kit Part# BK6301653 $15.99 Needed only if your old ones are bad
    Inner Wheel Bearing & Race set Part# BRGBR37 $18.99
    Outer Wheel Bearing & Race set Part# BRGBR35 $16.69
    Seal Part# NOS24898 $ 4.99
    Big-Bearing Spindle-Inner-Bearing Journal Size: 2.00"
    Hub Lock Nut Kit Part# BK6301653 $15.99 Needed only if old ones are bad
    Inner Wheel Bearing Part# BRG LM104949 $15.99
    Inner Wheel Bearing Race Part# BRG JLM104910 $ 9.49
    As you can see the only differance in the small and big bearing spindle is the inner bearing all the other parts are the same
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Holy 5 yr old thread digage there dude.
  10. 72blazerguy
    72blazerguy 3/4 ton status Premium Member
    Aug 6, 2007
    684
    8
    fairbanks, ak
    seems better than starting another thread "Why is there 2 different part numbers for Inner Bearing"
    At least it shows that he does some searching :rolleyes:
  11. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    There is so much great knowledge on this site over the years. To bad it is stuck within all these threads. This stuff needs to be put in a wiki or guide book.
