GM Part #?
Discussion in 'The Garage' started by PsychoticDeadGuy, Jan 8, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Is this a GM part? If so, what number is it?
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Kinda hard to see but are you referring to a Tie rod end with drag link whole in it?
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    Yep, I want to run high steer but only have one hole in the flat top arms. So I wanted to run the draglink into the tierod with that hole.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Not sure of a GM part # but its just a stock K5 tie rod end.
    The part # is ES2233L
    but you will need to ream out that hole to use it with a TRE. But doing that is going to take out alot of the meat around that area.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    exactly, thanks, are there any drawbacks for this kind of a setup?
  7. divorced
    Jul 20, 2004
    5,115
    I don't know enough about it to comment, someone else will have to name the pros/cons of this system. It is basically the same as the stock steering on the late 70's 1/2 ton Fords, which seem to work well.
