GM Performance Parts Serpentine Accessory Belt Drive System
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tonyraca, Oct 17, 2005.
  1. Tonyraca
    Tonyraca Registered Member
    Sep 28, 2000
    87
    San Jose, CA
    I have a 1979 Chevy Blazer with a SB350 that I am trying to fix up a bit and I am considering the GM Performance Parts "Serpentine Accessory Belt Drive System "Deluxe With Air" it comes with the items listed below. Does anyone have any experience with this system? I currently need at minimun a new steering pump, and my AC compressor is completely missing. I am also planning on replacing the stock clutch fan with an electric fan.
    This deluxe serpentine belt drive system with air conditioner includes all the components to install on small-block Chevrolet engines. The bolts, nuts, spacers and braces are included with the following major items:
    10055800 Secondary Air Injector pump bracket
    1134344 Air compressor assembly, (CR4)
    10129569 Idler belt pulley bracket
    88894005 Water pump kit
    10055880 Water pump pulley
    10055879 Crankshaft pulley
    10463172 Generator assembly (reman.)
    12117361 Generator connector (with lead)
    10055798 Drive Belt Tensioner Assembly
    10085752 Belt (fan, water pump, A/C pump, and generator)
    10105212 Generator & power steering bracket
    26010328 Power steering pump
    14102096 Power steering pulley
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    nope
  3. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I installed one without air conditioning.
    If you need the new accessories, I think it is a good deal. The parts on reman, but still better than buying it all separately.
    I had two major issues.
    One was with installing a factory water pump driven fan, so if you're going with electric you won't have that problem.
    The other was the alternator hookup. You need a 4 to 2 wire adapter. Read this and it will tell you all you need to know on that:
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hoe much does that kit cost? im considering serpentine as well.
  5. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    go to junk yard, probably get everything for under $50
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I used their kit w/o air. Really pleased with it. But as Mrk5 says, you'll need to sort the alt wiring out. (I had a little help from someone! :waytogo: :D )
  8. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    You've got some really cheap junkyards. The ones here wanted $500 for all that stuff. I ended up purchasing it from a fellow CK5'er.
    Try checking for a truck that was hit, or someone is parting privately. If they let you pull the stuff you can take pics and make sure you get everything you need.
  9. Tonyraca
    Sep 28, 2000
    87
    San Jose, CA
    At some point I am going to switch to a higher amp one wire alternator, but I don't know if I will do it now or later. I think in the long run the one wire will work better. I will let you know how it goes. Thanks for the heads up about the wiring.
  10. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
  11. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    I installed that kit on my Ram-Jet 350 this year. Works great. I did change all my accessories to the new generation stuff. Alt, powerstearing. I installed an electric fan. AC Delco has a conversion wire kit to convert the 2nd generation Alt to the newest 3rd generation wire pattern. I don't have the #'s anymore. I don't have air conditioning anymore, so I had to buy the pulley kit to replace the compressor. IMHO, it was worth installing.
