GM Performance TBI Heads
Discussion in 'The Garage' started by BigCountryx, Mar 22, 2006.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Anybody ever use the "285 HP" TBI Heads from GMPerformance? I am considering a mild 350 TBI Build and was wondering if there was any real advantage going with these vs. the stock swirl heads. I'm looking for afordability and ease of installation. I'd be happy waking this motor up to 260 - 285 hp if I could. Here's a link to the heads I was looking at.
    http://www.sdpc2000.com/catalog/3129/products/143/HP-TBI-SB-Chevrolet-Cast-Iron-Cylinder-Head.htm
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Well, I am of the opinion that stock TBI swirl port heads are some of the worst flowing heads that GM ever made. I can imagine that any heads like these would be an improvement for sure!
    You could also consider a set of 87 - 92 L98 F-body (Camaro, Trans Am, GTA etc), or 87-92 Y-Body (Corvette) TPI 350 heads, they are one of the better flowing stock heads made by GM, and if you get them from a Y-body they are made out of aluminum. The 87+ heads are center bolt, and have the correct intake bolt pattern for the TBI intake.
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Would these L98 heads or TPI heads your talking about be a direct bolt in for the TBI 350? I'm looking for something that will be a direct replacements, just flow a little better and give me a little more power. Probably gonna do a mild cam swap at the same time as well as TB mods and headers. I just don't want to start running into EGR issues and such. I Believe in the KISS (Keep It Simple Stupid) method most of the time. Thanks
  4. Russell
    Jun 23, 2000
    7,923
    333
    If you get the heads I mentioned, they'll be a direct bolt up. Everything is exactly the same from the head bolts, to the valve covers :)
    Make sure that you get a cam with a lobe seperation angle of at least 112 degrees, or your TBI will never run right afterwards.
  5. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Not to hijack but ive heard you can use a stock TPI cam in a tbi, and its supposed to be pretty good. Is there any truth to that? also are trucks are non roller cams right? and the TPI's are roller cam, so youd have to switch over to roller lifters?
  6. Russell
    Jun 23, 2000
    7,923
    333
    Not all TPI are roller cams, infact, most of them wouldn't be...
    I can imagine that a TPI cam would work fairly well with a TBI engine, as they'd have more lift etc, and are definitely EFI friendly.
  7. dyeager535
    26,979
    Since all the car engines were roller from '87-on whether carb, tbi or TPI, I'd say most are roller cammed. That would leave '85 and 86 as the only non-roller cam TPI stuff.
    If thirdgen's search was working, you could probably find all the comparative numbers, and results too. (from tbi to tpi cam swaps)
  8. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Also, Are the heads in the link that I provided just some L98 heads or some other GM heads that GMPP are marketing as High performance TBI heads?
  9. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
  10. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Got a set of Vortecs for sale in the classified section......
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'll second the S/R Torquers for a mild TBI buildup, if you plan on using a stock intake. if not, L31 Vortecs are the way to go.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If all you are looking for is 285 HP your stock heads can support that.
    Those GM TBI Performance heads are L98 heads. More for top end power than low end.
    With a manifold, Mild computer frendly roller cam, 1.6:1 rockers, headers, you can make your 260- 280 hp goals. It is really not that hard to push a TBI motor over 300 HP with a little port work on the heads.
    But
    once you start adding a lot of flow with aftermarket heads/port work you are going to have to do some chip work.
    If you stick with the stock heads the stock chip/ computer will be able to handle up to aprox 280 HP with an adjustable fuel pressure regulator and all the other TBI compontes in good working order.
    If you are looking for ease of install stick with the TBI heads they are really not bad of a head for a truck. (Flame suit on)
  13. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    If I use the stock heads and manage to squeeze 275-280 HP out of this engine, where will my torque numbers be and at what RPM will it fall on it's face? Also, what cam would be a good match for the stockers.
    BTW - I had a feeling that the Performance heads were L98's thanks.
  14. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    With the stock heads expect them to fall on their face around 4500 RPM.
    Good cams are Edelbrock 3702 or Crane 2020, or a 3030 if you want more midrange. Comp also has a mild computer frendly cam that works good in TBI. All these cams will work with a stock chip.
    You should have an edelbrock or holley manifold to go with them. Also headers.
    I would also use flat top pistons instead of the stock dished ones. flat tops will up the compression ratio to around 9:1. The stock chip can easily handle that and will make more power.
    A bored 46 mm (600cfm) TB and an adjustable FPR running 14-15 PSI will top things off nicely. Should get your injectors rebuilt/cleaned/flow matched or get new ones.
    Depending on the cam you will build all your torque in 2300 to 3000 range. The Crane 3030 will pull up to almost 4K
    And HP will peak around 4000. Perfict power band for a heavy truck and fuel economy.
  15. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    You da man Thunder, gives me some good ideas!
