GM quad shock suspension
Discussion in 'The Garage' started by tboldt40, Sep 28, 2005.
  1. tboldt40
    tboldt40 Registered Member
    Jun 11, 2005
    16
    Broomfield, CO
    I recently purchased a 87 K10 Chevy short bed with a 4" lift and 33s. I'm ordering replacement shocks for the truck. The issue is it has the quad shock suspension option on it. The previous owner only used single shocks on the front. The hardware for the second shock is missing. Did GM use a longer bolt and washer to mount both shocks to the the shock mount on the axle? Or is there something I'm missing? Any Pics or advice on hardware would be great.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yes, they used a longer bolt. Most people just run one. Running 2, depending on the shock, usually just results in a harsher ride.
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah, the factory hardware is basically just a longer bolt that allows the second shock to bolt up the the lower mount. Unless you are doing desert racing with lots of high speed whoops and stuff you don't need 2 shocks per wheel. One high quality shock per wheel is all you'll need.
    j
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    jus run one, itll ride better, plus its cheaper
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The lower factory mount just uses a long bolt and a spacer between the shocks so that they don't touch each other. I'm running just a single shock at each corner on my '90 Sub that came with quad shocks. Rides just fine... :cool1:
  6. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    well if you buy off the shelf shocks, you will get a harsher ride, but if you go to a professional and have him do the math, and figure out the correct valving, your shocks will last muchmuch longer, and you will have a better ride.
