GM side post battery terminals SUCK
Discussion in 'The Garage' started by thezentree, Oct 25, 2005.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    K, it's 7:23am and my truck won't start. I am supposed to be at work 23 minutes ago. Because my battery failed. My brand freaking new red top is useless because the pressed-in cap with threads for that stupid little bolt pulled out of the lead of the battery. What the hell is the point of that retarded design? It's hard to jump start anything off of it, and this is the FOURTH battery that I've had problems like this with. FOURTH! This crap makes me want that Superduty even more. So yea, you could say I'm pissed off. Optima declined to warranty my last red top that the exact same thing happened to. I really hope they've since pulled their heads outta their asses.
    On that note, does anyone have a suggestion for converting my truck to top-post style clamp terminals other than the crap Advanced Auto sells?
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Why didn't you get a battery with side posts and top posts???????????????
    And check here.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Bingo...Sears Truck, Van, SUV batt. Makes it an awful lot easier.
  4. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Saw in latest Four Wheeler mag some battery with 1250 cranking amps and a 10 year starting warranty. Thats crazy. I dont know where the cables mount on that sucker, but when my redtops die, Im going shopping....
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    What's so hard bout changing the cables out to top posts??
  6. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    I agree, I purchased cable ends and cut off the existing side-mount ends. After installing the new ends on the cables I put screw-in posts on the battery and everything is golden.
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    on my last truck i cut off the side post to the truck side and ran the aux batt in the side post, hooked the truck pwr feed to top post. it is super easy- chop em off!!!
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Either Optima is using too soft of a material for the posts, or you're overtightening the screws. I have 4 side post batteries in rigs right now and have never had one pull out of the battery.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are you using a battery hold-down? How tight are the cables? Those are the only reason I can see for your problem. I have run optimas for years and have only had 1 cable pull out. My mount broke and the battery ended up laying against the header with the positive cable supporting it. It started to pull the threads, but I just put in a bigger bolt.
  10. dyeager535
    26,977
    Can't comment on the Optima's in particular, but I've never had a problem with the terminals, and most of my vehicles the battery cables are coming off pretty often.
    Jump starting is certainly a pain, the dual post setups seem ideal for that.
    FWIW, the few top post batteries I've had corroded a lot quicker than the side terminals did.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I like to snug the side posts down , just for the starter and ground , never overtightening . I have the stock holddown block , and a top hold down with the 2 j-hooks , and the wires are long enough to have a service loop for movement . If I work on the truck I disconnect ground at the motor and leave the side posts alone .
    And all my accessory wiring goes to the top positive post . Been running that battery since 2002 .
    I have had side posts strip before , thats where I learned from :D
  12. thezentree
    Sep 19, 2003
    7,198
    NC
    It is the one with top and side posts, so I guess I'm gonna have to convert to top post style if I can't get the battery warrantied. Reason I didn't convert in the first place is why the hell should I modify my truck to work if the design is supposed to be functional. Kinda stupid to make a battery that won't work with a type of terminal.
  13. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    They sell adaptors..
    You can buy adapters to convert your side post cables to fit on a top post battery,so you dont have to cut them..they are a bit cheesy,but I have them on my truck,and they seem to work ok--but they strip easier than a batttery will,so dont torque the cable bolts too tight..only about 4 bucks a pair here..
    Another option is to heli-coil the battery threads..it isn't easy,but I have done a few sucessfully.. :crazy:
  14. globaljames
    globaljames Registered Member
    Apr 2, 2004
    52
    AZ. Scottsdale
    I run like Pauly stated. If you are stock with no additional cables etc you may be a little tough on the wrench especially if its the 4th time.
  15. thezentree
    Sep 19, 2003
    7,198
    NC
    I don't think I'm over-tightening it though. I've stripped those bolt heads before (that was probably pushing it, but they held for a good while), but this time they look brand new. I think the things are retarded and have advantage over a top post style terminal.
  16. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    That sux I have only had 1 problem with my red top an it was replaced for free. But mine has both top and side post so just get some better cables an top mount style connectors.
  17. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    red top battery
    when i flipped over my zr2 the red top optima broke in half the cables were still connectod to the upper portion while the bottom portion shot through a hole in the fender, they found the other half of the battery 50 yards from where the truck landed. so i would say the side post were plenty strong.
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i run everlast from walmart 1000ca and 875cca, and its side post and top psot so u got both!!! and has a 3 year replacement warrenty. ive got some electrical problems in mine, amd it kills teh battery every couple weeks or so...ive been goin back to walmart everytime and gettin a new one, im too lazy to deal with the wiring right now :haha: ive been doing this since about march, they still havent asked any questions yet :D
  19. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    for those who care, the 99 and up grand ams have longer battery bolts than normal. there is plenty of room to hook up jumper cables. bolts are a couple bucks though. last i checked they were about $3.50 a pop.
    ryan
  20. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Nice :confused: - way to abuse the system.
