GM techs and Vortec truck owners, Rod Bearing knock?
Discussion in 'The Garage' started by sled_dog, Feb 22, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Anyone experienced a cold rod bearing knock from their Vortec engine? I was bored at work today(very very slow) and started looking up all the service info on my daily driver since it has a few issues. One of them is when it is really cold it has a rod knock at low rpms. There is a TSB for that exact thing, a cold, low rpm rod knock. Recommends new rod bearings. Also stated that some of the Vortec engines have a problem with crank bearings. Anyone tell me how to tell if my rig is affected by the crank issue other than pulling the oil pan? And anyone dealt with the rod knock thing? I was kind of figuring if the engine has to come out I might as well slap together another one so all I have to do is pull the intake and wiring assembly and throw in a fresh, maybe more powerful engine.
  2. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    My motor does that, it lasts for about 10 seconds then goes away once the idle comes up.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    ive seen plenty of vortecs both 4.3 and 5.7 go out after an intake manifold change. always the rod bearings though. seems that abrasive discs and cleaning the cast iron dont mix.
    havent seen one go from just wearing out though. fwiw over the last 4 years at gm dealer.
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Research a term called "piston slap"
    You'll find that is what you have for the 10 or so seconds when you first fire up.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    piston slap is for the gen III/IV engines.
    vortec engines like sleds are the old 350
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its not piston slap. Well it can sort of be piston slap. The TSB clearly states it is a rod bearing issue. Like Ryan said, Piston slap is a Gen III/IV engine issue not Gen I Vortec.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My Vortec 6.0L in my 01 Chevy 2500 does it. It only does it when its cold out and lasts until the engine warms up. The 6.0's are notorious for this and ive never heard of it causing any damage. I just liek to think that I have a diesel in the morning:D
  8. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Ah, when you said vortec. thats the first thing that popped into the knoggin. Didn't know you had an older one.
  9. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    mine is an older block as well
    actually its not a vortec...
  10. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    My 98 does that sometimes.... I run the piss out of it and nothing has happend yet... Wonder if theres anything that could be done, mine only has 63k miles on it... I had never really read the TSBs. Fill me in further Allan
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'll try and print the TSBs if I have free time today. Mine has a little over 100K on the clock and just recently started doing this.
  12. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    At my uncles JY, nearly alll of the vortecs we saw ha either a spun rod bearing or cracked head, and usually both.
  13. Hermy13
    Hermy13 Registered Member
    Aug 27, 2005
    22
    Iowa
    After changing my great leaky intake gaskets 1000 miles down the road the crank welded up on the bearing. 150k on it
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i havent owned an 88-96 truck that didnt do it. never had any problems out of them either.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    was that an internal coolant leak? That would make sense, antifreeze destroys bearings. The intake leak I had was an external one.
  16. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I have a 79 350 with 125000 on the short block, that has been doing it for about 50000 miles now, a cold start up will knock for about 5-7 times then quiets down, and sounds normal.
  17. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    Is this the engine that requires the "check-valve oil filter"? I know most of us throw the same old filter on as we do our other Chevys, and that might be a problem. Does this ring a bell with anyone?
  18. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I was talking to the owner of an engine shop about putting a serpentine belt setup on my old 400 and he advised against it.
    He has a newer chevy p/u an went over to it, started it up, and pointed out the slight knock on startup.
    His theory was the extra grip the serpentine belt provided, caused the crank to move untill it got oil pressure at the bearing. He said the engines are still quite tough, they all do it, and GM wont do anything for it. But he would not recommend putting the serp. setup on my motor.
    Now that is his viewpoint, but he has much more knowledge than me in this area, so I'm thinking of taking his advise and sticking with V-belts
  19. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    same hear buddy.:rolleyes:
  20. sweetk30
    Nov 1, 2004
    25,554
    548
    good point but the check valve only is needed for the filters that mount up side down. this is to keep oil in it when off. are filters mount up on the old motors. and the 88-up 4x4s run a smaller one that mounts sidways .
