GMC Quadrasteer. Hot new swap for Blazers?
Discussion in 'The Garage' started by Sandman, Oct 15, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    How long untill we can pull one from the Boneyard?
    Quadrasteer (Then select "QUADRASTEER" on the left)
    Love to have this. /forums/images/graemlins/grin.gif
  2. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    design news write up Complicated and $$$$. Plus same toaster oven, aka rock magnet, issues. Now with some rework...
  3. Grim-Reaper
    7,385
    Atlanta
    Oyyyyy. That would be a mess. If I was going to mess with 4ws I would go Rockwells or if I had some cash get Jact at CTM to build one of thos Ford 9 inch/Mog hybrid portal axles like the JR's Bronco (aka Fat City) has under it. Mog axles (the diff) don't like high speed but with the 9 inch center that is taken care of and gives you the gear options. Then just run hydro steer on a joy stick and not mess with the electronic Wizardry. For what we do that would be the way to go. you would want total manual control and not what some idiot a GM decided it should do. Driving sideways at 50mph would be fun too /forums/images/graemlins/smile.gif
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    A rear Dana 60 might be an idea also...
  5. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    who is CTM and do they have a web site?
  6. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    CTM
    I have a 14 bolt w/ a bad spindle, and I got some 60 inner and outer knuckles off ebay. Going to see how that works for rear steer set up. Have always wanted rear steering. Don't know why. /forums/images/graemlins/tongue.gif
  7. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i believe the new quadrasteer rear axle is a dana 60 from what i've heard.good luck finding one in a bone yard,not to mention the price.but all in all it would be cool to have 4 wheel steering.then i could keep up with those damn "heeps" in the real tight trails.
  8. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    doesn't turn very far, expensive, and most of all, it's computer controlled. i'm kinda sketchy on what these people are going to do when they're towing a trailer at 70 on the interstate and the rear axle decides to make a right turn.
  9. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The rear steering only works below 25 mph /forums/images/graemlins/thumb.gif
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
  11. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    afroman006 check out the design news piece linked in the second post. Tells you how it works and all the failsafes. The quadrasteer works at all speeds.
    twiztid, how was backing up with it? (that tv ad with guy backing up doing figure 8s with a trailer)
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. That was good info. /forums/images/graemlins/thumb.gif
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Actually, the rear steering changes it's method of operation at either 25 or 40 mph. In "towing" mode, the rear steer changes from negative rear steer to positive rear steer at 25 mph. In "normal" mode, it changes at 40 mph. /forums/images/graemlins/cool.gif The change isn't made instantly though. Negative rear steering is gradually reduced as the truck approaches the changeover speed, then gradually introduces positive rear steering as the truck exceeds the changeover speed. /forums/images/graemlins/thumb.gif
  14. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think your right. Low speeds it turns the oppicite way for a sharper turn and high speeds it turn the say way so ur trailder dosent move like a snake and more like 1 peice
  15. afroman006
    Aug 21, 2002
    2,876
    Oh... Cool thx
