GMC Quadrasteer question.
Discussion in 'The Garage' started by BigOrange90Jimmy, Mar 30, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Went to the GMC dealership today and studied the quadrasteer pickup a little more. Yeah the rearend is huge and the knuckles are too. I had one question though. Is there an actual u-joint in the axleshafts of that rearend, or is it a kind of CV joint? I was looking at it and it appeared to have either a dust boot over where the universal should be in the knuckle or it was a CV. Just wondering if anyone could verify.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I'll check and see in the comps at work.
  3. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    It is a CV.
    Also it is larger than the 60 size CV used in the 2500/3500 trucks. We make most of the truck CVs. However our largest press (2000ton) can't form the Q-steer CVs, so I'm told by the engineers.
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Aight, now I have another question. Could the CV hold the angles of a front steering axle? And if it could, why isn't anyone using it, if it's substantially stronger? I know it'd be really expensive to make, but it would make sense.
  5. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    No the CV can't handle the same angle as the front, as far as I know. Also it might not be a CV in the sense of the outters on the front, it may be a large tri-pot design. If I get a chance I'll swing by the garage an look at some. IIRC, the rear is only intended to operate at a max angle of ~12*.
    In the stock application the front half-shafts are plenty stout.
