Go Go Gas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Jun 21, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    would nitro work on a blazer and do any of you have it?
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Why??????
    Seams to me if you want to go fast buy a hot rod!
    A Blazer is not a good canadate for nitro[​IMG].............
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. James90
    May 18, 2000
    986
    Rocky Mount NC
    I would like to have a hotrod but they dont do all that good in the mud I dont rock caw or any thing like that and in the mud there is lots of times I conld have used that hp and form what I have herd nitro cost less than a hipro eingen now I might be worng I dont know what it take to run nitro
    [​IMG]Go prepared
  4. Burt4x4
    6,854
    I don't know a thing about nitro except it gives a sudden burst of power and I would think if you did that to a 4x4 you would start popin Ujoints and such!!???
    Duno????????
  5. James90
    May 18, 2000
    986
    Rocky Mount NC
    I would porbly need a steel seat to stop form geting a ujoint up the butt
    [​IMG]Go prepared
  6. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    My feeling is that if you add nitro to your motor your lookin' for trouble. For an engine to seriously use nitro it needs to be built to support it. You might get away with one of the cheap kits that adds up to 125 horse, but it'll wear out your motor really quick.
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  7. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Are you talking about Nitrous Oxide, or Nitromethane? Nitromethane is the fuel used in top fuel drag cars and requires like 13:1 compression, because it doesn't burn as fast as gasoline. That's why it is still burning when it comes out the headers. You would have to make extensive modifications to your engine to run nitromethane.
    Nitrous Oxide is not a fuel, it is a gas (not liquid, vapor) that condenses the air fuel mixture so more air and fuel get into the combustion chamber. Nitrous oxide will give you a quick boost of power when you need it.
    Jeff427
    <font color=red>Mud Dog Off Road Club</font color=red>
    http://jeff427.coloradok5.com
