Go Rhino Axle Trusses
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slider, Nov 16, 2001.
  1. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Any one have a picture of their rig with a set of these axle trusses installed? I bought a used set and I am trying to figure out the mounting bolts. The bolts look like shock bolts for a chevy truck?. If anyone has these on their rig can you help a fellow wheeler out. Thanks Jeff
  2. slider
    May 7, 2001
    547
    I know someone must have a set on their rig or know someone who comes to this site who does.
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i HAD one on, but after it caught on every rock at tellico, i took it off. make sure you have all the hardware to mount it up.
    rt side- 2 semi-circular metal pieces with bolt holes on each side wrap around the axle tube and tightening these bolts "clamps" the tube. there is a little tab that sticks out that goes under the ubolt (i think, because i ground mine off!)
    middle- same as rt. side mius the little tab.
    lt side- the bracket is a little different as the semi-circular mount has 2 little tabs that mount to the truss and the bolts will be fore and aft of the axle.
    damn, this sounds confusing----i will try to find some pics though
    rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  4. slider
    May 7, 2001
    547
    I went to your picture page and saw you had one on the front. Did you ever have one on the rear? If someone can find a couple of pictures I would be forever thankful. I have the drivers side mount but I seem to be missing the passengers side. I contacted Rhino and they have a mounting kit for 25.00 so i think that will be money well spent
  5. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    HOLD ON!!! i have my old ones....send me ten bucks to cover the ride and they are yours!!!
    BTW-i have all 3 for the front. you will have to get three of the bolts your self though,
    rob
  6. slider
    May 7, 2001
    547
    Did the front have three or four? Either way send me a e mail so we can get adresses. Contact me send me a private mail Thanks dude
    <P ID="edit"><FONT class="small">Edited by slider on 11/16/01 07:30 PM.</FONT></P>
