Goes flat on tip in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86K5inMN, Mar 14, 2002.
  1. 86K5inMN
    86K5inMN Registered Member
    Aug 7, 2000
    28
    Minnesota
    I'm having a problem with my truck. It started last night after a long drive at about 65mph. Just after throttlr tip in the engine goes flat. it won't accelerate. I can slowly work my way up to the right speed but it takes awhile. The engine has 109000 on it and hasn't had much work other than tune-up stuff including the fuel filter and a new fuel pump. I kind of wonder about the transmission condition as I am the third owner and I have no idea what the truck was used for. Any help would be appreciated. I can't check posts very often as I am out-of-town but I will check them this weekend.
    Thank You
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Is the 86 computer controlled ignition?
    Is it fuel injected.. I forget. Sorry.
    I would say ignition timing or vacuum leak.
    I find when mine doesn't accelerate when I hit the pedal hard, it is because the timing is too retarded.
    If fuel injected, check engine codes.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    on a card'd engine that is accelerator pump
    would that be MAP on a fuelie
  4. 86K5inMN
    Aug 7, 2000
    28
    Minnesota
    Sorry, it is a computer controlled carb. I've done alot with cars but not much with carbs, especially the quadrajet. Is the accel pump an easy fix. For a few more days I have access to a spare vehicle so now would be the time to do it.
  5. dyeager535
    26,975
    Accel pump is an easy fix, also an easy test.
    After vehicle has been running, remove the air cleaner. While looking into the primaries, either operate the throttle linkage to WOT (fairly quickly) or press the accelerator pump down with your finger...its on the top drivers side front of the carb, and has a green arm that presses on it. If you see a strong squirt of gas, your accelerator pump is working. If no squirt, or a dribble, it's got problems.
