going BBC!!!!!!! help me choose a cam!!!!!!
Discussion in 'The Garage' started by steve_kibbe, Nov 5, 2004.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I've started my BBC project and wonder what kinda cam to get?
    I want something for good allround use. I don't mind a lope
    to the idle.....I'd rather have a lope /forums/images/graemlins/peace.gif
    Let me know what y'all think /forums/images/graemlins/thumb.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Need alittle more info. What transmission are you going too use ?? Will you be doing and rock crawling ?? I'd call up Comp Cams 1-800-cam-help give them all the info and see what they recomend.
  3. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I have a suggestion but it will be better suited(sp?) for mud. It's also not EFI friendly.
    Crane Cam Page
    Pros - LOTS of torque / lopey idle / street friendly / works well with auto and 4spd.
    Cons - no vacuum so you'll need a cannister if you have power brakes / it's hungry
    I have used this cam in two motors and will be using it again in my new motor. TARussell and I also put this cam in Ratzilla's current motor.
  4. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Also depends on gear ratio, compression, and if an auto do you have a stall coverter. Don't forget about new springs as well. Past experience has taught me that springs will "take a set" over time and a new cam profile can cause a spring to break. Over all I've been fairly impressed with Comp cams 4x4 extreme series, especially the K kit /forums/images/graemlins/thumb.gif
  5. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    thanks for y'alls reply's /forums/images/graemlins/thumb.gif
    I plan on doing a little bit of everything. Not heavy rock for sure, but a little. This thing will see alot of dirt and muddy terrain. I'm in the south east. I'm planning on having 4:56 or 4:88 gears with 38 or 39.5 tires. I have an 350 auto tranny.
    I plan on changing valve springs, push rods, rockers. Compression ratio will be less than 10:1 I only want to run pump gas, I don't mind high test. I plan on using a new stock converter, but am open to sugestions /forums/images/graemlins/thumb.gif I'm going to run a carb, prolly holley truck advenger.
