Going crossover
Discussion in 'OffRoad Design' started by Muddytazz, Apr 15, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    With 5" - 6" lift in the front, will I need a spacer under my pass side steering arm for the draglink?
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm not too familiar with the 10 Bolt / Dana 44 crossover set ups, but I think you'll need to lose the sway bar. I think .....
    Eric M.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    sway bar is the least of my worries, its going in the trash when i install the crossover anyways /forums/images/graemlins/thumb.gif
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    With the zero rate in the front, you probably will need to space the arm up. That's not a great situation, but it can be workable. Especially if you do some easy tricks like tack welding the arm and spacer together.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thats actually not a zero rate per say....it started life as a 1" thick piece of steel, but I milled in a 3* taper.
