Going Dashless
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jul 20, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I got my new dash bezel in today after like a month but it was a good deal $80 so I'm not complaining (too much) I took out the gauges and cleaned them and replaced the burned out lights and cleaned the gauges but I put the plastic piece back on and it cracked ($60). So now I don't have the dash pad or the bezel on and my lights are still flickering. I already replaced the bulb and when I first start driving its out but it comes on later. I want to fix this but does anybody know what is wrong with it I'vealready checked the connectors and they are fine. also used steel wool to lightly rub off some of the stuff on the connection.
    90K5
  2. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Did you check the connections on the headlight switch/dimmer? The contacts get old and worn, or just dirty, and it makes your dash lights flicker. Every GM car I've ever had has done this after a while.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    CHECK YOUR GROUNDS
    89 w/DANA 60-Corp 14 w/5:13s n Detroit's. 4"lift 2" body. NEW AtlassII being installed
