going for a TH350 to a TH400 and have some???
Discussion in 'The Garage' started by 77ChevyK10, Nov 12, 2004.
  1. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    I have a TH350 torque converter and shifter but I am going to a TH400 /forums/images/graemlins/woot.gif. So will the TC and sifter linkage work or do I have to get another TC and buy a floor shifter?
  2. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    A TH350 converter will work fine in a TH400, but it will give slightly higher stall than the TH400 converter. Maybe a few hundred RPM. The stock shifter will work fine. Sometimes it helps to have the offset shifter arm bolted on the trans, but you don't need it. /forums/images/graemlins/smile.gif
  3. 77ChevyK10
    Feb 2, 2003
    317
    Laveen, AZ
    thanks for the info that helps alot.
  4. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I thought the kick down was different between the 350 and 400. With the 350 being mechanical and the 400 electric. But I could be mistaken.
