Going from 10 bolts to 14 bolt/d44 or d60 what do i need to do?
Discussion in 'The Garage' started by Lotsa_Faith, May 30, 2004.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    What all is involved in this as far as driveshaft mods and brakelines and whatnot? My back 10 bolts a little jacked up so im just gonna get it all done right now w/some 4.10's or better...
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You will need a conversion u joint in the rear to hook up your driveshaft and whatever it takes to get the brakes on your new axles up to snuff. You will also need 8 lug wheels with tires of your choice on them. New u bolts front and rear are also a must.
    If you go with a D60 and you have a lift you will need steering correction or to go to a crossover steering setup which will cost you about $400.
