going from 4" lift to 2-1/2"....steering arm conical washers?
Discussion in 'The Garage' started by hunter, Feb 26, 2005.
  1. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    I bought a 1989 Jimmy with a 4" superlift and 33's and it has tons of clearance. I really only wanna run 33's so Im thinking of putting a 2-1/2" lift on, therefore I need to put the stock steering arm back on right?
    Can I re-use the conical washers on the steering arm swap or should I purchase new ones? (they are very expensive...like $15ea from LMC)
    BTW.....Anyone near houston wanna swap there 2-1/2" lift for a 6mo old superlift softride? :cool1:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran a 4" raised steering arm on my truck with 2.5" lift. It worked fine. I noticed a little more bump steer at first but I got used to it and it never bothered me. I would say leave it.
    If you do put the stock arm back on you can reuse the conical washers as long as they are not all beat up. If you need new ones there are alot of places to get them on the net for alot cheaper then LMC. $6 each comes to mind.
    Harley
  3. hunter
    Oct 28, 2004
    52
    Houston,Texas
    Thanks, that would be great if I didnt have to swap the steering arm, it would make the change much easier.
    Got any links to order those washers online just in case?
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  5. Habez
    Habez Registered Member
    Mar 27, 2003
    45
    Houghton/Frankenmuth, MI
    I found the conical washers for about a dollar each at a shop around my place
  6. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    i would swap my 2 inch front springs and rear add a leafs, dont know how old they are and who made them but they can clear 33s no problem
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Add a leaves are stiff as hell.
    I'd leave the 4" lift and just throw some 35s on later.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I wouldn't worry a bit with a 4" arm and a 2.5" lift. 2.5 is closer to 4 than it is to 0 anyway.
