going from manual to auto
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snidgen, May 16, 2000.
  1. snidgen
    snidgen Registered Member
    Mar 5, 2000
    47
    I was wondering if there are any problems I am going to run into when i change my 1972 SM465 manual tranny to a TH400 auto? What about length and t-case(NP205) attachment? Will the same speedo cable work? I have not bought a automatic yet are any years better than others? What kind of shifter do you all recomend?
    Peace,love,and 4wd is all you need
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Two questions:
    1) Why on earth would you whant a hot slusshy over the 4speed??
    2) can I have your sm465 if you still decide to do the swap[​IMG]
    I am just a huge cluch fannatic only cuz I Love to drive and a slush box it way too boaring for me!!
    Good luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I know you will need a kick down switch these are avalible
    from summit racing. B&M makes a truck shifter, not sure if it will work with a 4x4 because of the transfer case shifter. will need t-case adapter and possibly lengthen or shorten the drive shafts. Should be able to use same speedo cable if it is not too short.
  4. Grim-Reaper
    7,385
    Atlanta
    Try to find a 400 with the case because the input on the Manual set up 205 is different than the Auto version. In the long run it will be easier and cheaper. Then completly take out the clutch assemebly and put it in a box and and ship it to me :)
    Diging it in the dirt with my K5's
    Grim-Reaper
