going from points to hei
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snidgen, Jun 7, 2000.
  1. snidgen
    snidgen Registered Member
    Mar 5, 2000
    47
    What are the considerations when converting from points to HEI ignition? Any wiring? Any timing or vacuum advance problems? Or does it just drop in. Oh yeah its a GM crate 350
    Peace,love,and 4wd is all you need
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I say forget the HEI stuff and drop in the MSD Pro-Billet 8360 ready to run distributer with a blaster 2 coil!!!
    It will hook right up to your stock wires and the coil goes into the stock coil holder!! I have this setup and its sweet!!! No box to run all the electronics are in the base of the dist!! You can how ever add a MSD box if you want to but thats another 150 bucks!!
    Good Luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ys, I say drop the HEI also.
    I ran MSD too. I ave an MSD 6a box, High Vibration coil(can be mounted in any direction) and a MSD Billet Distributor with SLip collar.
    MSD is a great set up!
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I went from points to HEI on my '74. The HEI I bought at a swap meet had an MSD board inside it. I was having a bad plug fouling problem that is completely gone now! I also went with Bosch Platinum plugs. Now, for your question, the unit will just drop in, but you need to run a nice +12 volts from the ignition switch (or circuit) to the B+ on you new HEI. The points trucks have a "dropping" resistor wire that reduces the voltage a little for point longevity. Set the timing pretty much the same and there ya go. If ya wanna run a tach you can just plug a .250 female spade onto the "Tach" terminal on the HEI cap and you're there.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
