Going Hybrid!!!
Discussion in 'The Garage' started by Mudzer, Dec 18, 2003.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Well, this past weekend's snow run was the last I'll take in my bulky K5 - 'Tis time to trim the phat!
    I've located a couple of S-10 Pickup Cab's and have begun the thought process of how this rig will turn out.
    Tyler Birkey knows eeezackly how I will build it too! Ever since I saw Beau Byrom's rig at Mudstock, I have flipped through the many pics I took of his rig. He has since rolled this beauty, so I'll steal his concepts and take them a little further! Here's a pic of Beau's rig, shortly before the roll!
    http://www.4wheelingplus.com/images/Pic-6.jpg
    He started out with a 2+2 1 Ton 4x4 and shortened the frame - I'll be using my current frame and drivetrain. He installed a clean S-10 cab on the frame and hacked out the front portion of the fenders. I might steal some ideas from White Knight for the front tubework. The cab sits nearly perfectly centered front to back on the frame. There will be an intergral roll cage inside the cab. Planning on welding in the "Watson Console" look as well as the "V" uprights in between the A-Pillar (like Watson's). It will likely get Half-Door treatment someday.
    The rear bed section will be made from Aluminum Diamond Plate and will be covered by a second roll bar/cage that coveres the fuel cell, tool box and cooler storage.
    Overall, I think this will be much more fun on the trails. I will also lower the truck a little to keep the CG down for uphill and offcamber situations. It will be leaf sprung for the first building stage. /forums/images/graemlins/grin.gif
    Frisbie - get that garage cleaned out, we've got some tubework to do! We will work out payment arrangements later /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
    Will Work for Fabwork....
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    I thought you would say you were going gas/electric.
  3. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    have you seen that what-ya-ma-call-it kit that bolts on a frame like yours. Can't think of the name right now...but it is a buggy-like setup w/ four seats, a full body, yet huge tire clearance. Just a thought.
    Ernest
  4. Mudzer
    3,639
    Missouri
    Yeah, but I'm keeping the whole GM theme brother! /forums/images/graemlins/thumb.gif
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    how much weight do you plan on saving?
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Yeah, that was a hell of a rig, cant beat running 44s with NO LIFT, having awesome visibility, and much less weight.
    Tyler
  7. Mudzer
    3,639
    Missouri
    No way I can be sure at this point. I'll get numbers prior to and after the swap!
    The key is, I will be saving weight and having a lower CG.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Tyler
    at some point you want some lift to get the junk off the rocks.
    4-6" lift with 44's will get the belly up and keep the firewall from interfearing.
  9. Mudzer
    3,639
    Missouri
    Or, you could build a custom doubler (I did) and get a flat belly pan and gain that 4-6" back over a standard doubler. How much does yours hang down? /forums/images/graemlins/grin.gif
    I will leave my current 6" lift intact for a while, then see about removing leaves to soften up the ride. /forums/images/graemlins/thumb.gif
  10. BlueBlazer
    Feb 15, 2001
    1,940
    Think about it, he would have about the same frame to ground clearance as say a truck with 4" lift and 37s or so, plus with the s10 body i dont think he had any problem with firewall clearance.
  11. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    looking back... i kind of wish i would have done this...
  12. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    s-10s are small inside... why not go full exo instead of full internal cage? thats what I plan on doin when i go s-10. At any rate, good luck... and take LOTS of pics of the build-up. /forums/images/graemlins/grin.gif
    j
  13. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    What are people paying for s-10 cab's? I might go this route to shed some size and weight.
  14. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    Taking leafs out sounds like a good plan. IT will give you a long spring with lots of droop. How low can you really go with your current steering setup ?? Anything below four inchs and maybe a flatter draglink would be used, then maybe a different engine crossmember to clear a flat link ?
    How did that guy do his steering ? With stock leafs, i dont see room to do crossover. And with the twisty trails in Fulton and such, you gotta have it.
    Let me know if you will be around friday night or saturday.
    Blake
  15. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Make sure you keep us up to date on the project...pics...pics....pics /forums/images/graemlins/smile.gif
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    pix and pix and more pix... especially of how you solve tradition going-hybrid problems like custom body mounts, front clip mods and all that jazz. /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
    j
  17. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Good luck! You will be happy when you are done. Couple of hints- make your own body to frame mounts (don't bother adapting to your frame, saves time), use a Sub frame (straight and light)if you want to lengthen wheelbase (I used Blazer frame with S-10 Blazer body, my brother used Sub shortened to 115" with S-10 Ext. cab, I wish mine was that long, it makes difference), if you keep S-10 core support you have options for smaller and lighter radiators (check JTR.com), I would do exo cage (more room inside and offers body protection from pesky rocks, and take advantage of body off frame to any chassis mods (sooo much easier).
