going to a 12 bolt rear, are discs worth it?
Discussion in 'The Garage' started by K30Blazer, Oct 14, 2005.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I have a 10 bolt rear and will be installing a 12 bolt real soon. Is it worth the disc conversion? I have never really had a problem with my drums? What am I looking at cos wise?
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    probably a lot. wait til you break it and invest in a 14bff w/discs.
  3. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Going from 10 to 12 bolt won't gain much. But I've got rear disc on my 12 bolt and the setup kept my axle in and my wheel on when I did snap a shaft.
  4. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    my '73 with 12 bolt drums stops much worse than the '78 14 b ff with drums- so drums aren't necessarily the culprit. Personally, I wouldn't spend the money ona 12 bolt disc conversion, because if your tires are big enough to need discs than you should be running a 14 b anyway. That's my opinion
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats on one of my future to do lists , just to hold the axles in as mentioned before . My drums work fine for now .
    As for my 12 bolt drums , which were earlier and skinnier , I don't run them , I gave them away for beer .
    I simply ( with friends help ) undid the backing plates off my original 10 bolt , undid the clips holding the hardlines to axle , and lifted them up whole , dropped axle down , put 12 bolt in , attached 10 bolt brakes without opening a line :D
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    That's why I would like to do it, too.
    My biggest concern is the parking brake. If I do the disc brake swap, I want to make sure I still have the parking brake and I haven't heard too many success stories getting that to work.
