Going to do York compressor... ?'s
Discussion in 'The Garage' started by RootBreaker, Mar 16, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    Ok first is first.. I did search and came up with to go with a York compressor from a volvo. The compressor will be a square one that can be had from around a 1981 volvo (160, 260, ?? dunno that part)
    anyhow.. once I obtain this ac compressor.. what is next on my shopping list???
    custom brackets
    belt to motor
    air tank
    air hose to go from compressor to tank
    what else?????
    I do not have ac in my truck so I am assuming (yes ass-uming) that I can get the balancer pulley from a chevy 350 with ac as it should have an extra spot for the ac belt?
    I am almost finished with my rear disc conversion (wife wants the e-brake to work so ordered a caliper from autozone - already had a bad one from them so not happy)
    Next is the 140 amp alt upgrade - have alt
    zero rates gonna get ordered and take big shackles off
    gonna get a receiver hitch - $25 from junkyard - already found it
    then the York compressor upgrade.....
    so all in all I am getting off to a good start in 2005 :cool1:
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    If you want to have a nice automatic setup, I would get a pop-off valve, pressure switch, check valve, pressure guage, wire/switch, and a myriad of fittings. There's really no telling what you'll need in that area till you start to put it together. I think I made about 5 trips to the hardware store before it was "complete".
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
