Going to HEI....one ?
Discussion in 'The Garage' started by steedalx, Oct 19, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Yep and you also need to run a larger ignition wire to the distributor to replace the smallish stock one.
  3. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    OK I got it ordered, should be in by the weekend. I'm just looking through my Haynes manual and trying to determine which wiring diagram to use. Can someone go over which wires go where on the HEI unit.
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If I remember correctly, from my 70 Burb, All you need to do is put a new end on the hot wire that went to the coil and plug it into the IGN port on the new HEI. Its been about 20 years since I did this swap, but I remember that it was dead nuts simple. If I'm wrong, I'm sure that someone else will jump in and expose my poor memory.
  5. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    You need to run a new 10 or 12 gauge wire from the fuse block(hot only when key is in the "on"position)-the original wire to the points style coil is a resistance wire,wont allow the full 12 volts and amperage the HEI needs to work properly--sure it will run,but not at full spark potential.At my friends shop nearly every(older) GM truck he has worked on the owner had swapped in an HEI distributor had used the original coil wire--that turned out to be the reason the truck was brought in for a "tune up"more often than not--the trucks would not run well while pulling a load,or taking off from a dead stop,but ran ok under lighter loads--classic symptoms of weak spark.Low voltage to the HEI module can shorten its life quite a bit also. /forums/images/graemlins/crazy.gif
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    You can also use a relay. Trigger it with a IGN only hot wire (like the original points coil wire), and pull the high amp power from the battery.
    I have some concerns about pulling the kind of current an HEI requires thru a circut not designed for it.
    Another way to go if you're considering using a MSD or similar box is to go with a small body HEI from Dave's Small body HEI's. Don't know the URL exactly, but a search should turn him up. Basically what he does is put the pick-up coil and relutor from an HEI in a points dist body. I can also do this work, but right now I'm back-up too far to take on more work.
  7. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    Thanks for the help. Now this new wire that I run to the Coil, do I need to do it like the points system and splice a wire from it to the starter? Thanks
  8. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    You only need the one (new)wire--the old points system had a wire from the solenoid to by pass the resistance wire and give the coil full 12 volts while cranking only,to increase the intensity of the spark--HEI needs 12 volts direct,with no resistance,use a heavy wire like 10 or 12 gauge,it draws quite a bit of juice. /forums/images/graemlins/crazy.gif
  9. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    Makes perfect sense....thanks
