Going to look at a 79 4x4 crew cab.....Need with it help FAST!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Feb 10, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    It has a six in it. Not for long anyway. I am wondering what I shound look for? Looks like I will can get the truck for very little. Thanks for the help. Mike
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Re: Going to look at a 79 4x4 crew cab..........
    If it's a full time truck it could have the 400/203 combo which is popular for the ORD Doubler. I could be wrong but I think 4.56's are fairly common in the 6cyl 1 ton trucks. /forums/images/graemlins/thumb.gif
    Keep us posted! If it has a 292 6cyl I have a V8 crossmember assembly that I'll trade you for yours when you do the swap (they're slightly different for the 292).
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Ok...Thanks I will let you know. Mike
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I agree about the gear in the 292 equiped K-30's . A lot of the ones that I have seen have been 4.56's.
    Great find !!! Let us know how it turns out ....
    Tom
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool me to...this friday!! but this one has a 350 in it..and a flat bed on the back...not sure if its a dually or not..im guessing it is though..if i do buy it im ganna put a bed back on it...if i dont get the truck there is also a 77 k5 i might get ot loo kat for 999 as well!
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Re: Going to look at a 79 4x4 crew cab......Need help with it FAST!!
    I got to see it today. He said I could take it for 800. Got it down to 650. He is losing his storage. I need to get it out by Thursday at noon. I know a bunch of other guys looked at it. I was the first one. Here is the problem. Around the windshield is VERY rusted and so it just below it witch I think is called the cowl. They stopped using the truck because of the water getting in and causing mildew. Other then that 52000 original miles and it is not missing a thing. From what they told me is should start right up. How much $$ to make it part time? Fix the cab or maybe look for a new one. Anybody have one?? I can get my hand on a mild 383 or a stock 427. What kind of work is needed to drop it in? Thanks a lot for the help!! Any other advice would be great!! Mike
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You are talking about a 4x4 crew cab so that means 1ton axles, and thick tall frame, at 650 I would get it and then worry about the rest.
    Worst case you can put another body on or remove all the mechanicals under the hood when you want to replace the engine and clean up the firewall and cowl and make some patches.
    For the part time kit there is a write up by Grim Reaper it has all the info you need, it should be a sticky in the begining of this forum.
    As for the engine choices, anything Chevy will bolt up no problem.
  8. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    My God Man go and buy it RIGHT NOW !!!!! $650.00 is great for a k-30 that has axles still in it .
    You mentioned that it had a 6 cyl. It should be a 292 that has the passenger side motor mount in a different spot than the 250 , and SBC , and BBC's - Like Nvrenuf said , you will need to swap the engine mounts and cross member for the non-292 set up .
    It sucks that it is that rusted but get it anyway - IT IS A K-30 for $650.00 ....What more do you have to think about .....
    In case you haven't noticed , my vote is to get it .
    Good Luck , Tom
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Here is the problem
    Problem!? /forums/images/graemlins/confused.gif
    A dana60 and 14bolt for $650 in drive home condition. Where's the problem!
    It would have been on my trailer before he had found the keys /forums/images/graemlins/eek.gif.
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Somebody a while back had brand new in GM crate full crew cab (just the metal) on eBay. Included doors. I think it was up for a few grand and never sold. You could look it up and ask him to re-auction it...
