Going Topless
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Jul 18, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i have a question.
    how do u take off the top? liek does anyone have any good sugestions? and how heavy is the top to an 85?
    '85 K5: BIG BAD AND MEAN
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    <font color=blue>Go check out the Technical Page of this site. It might give you some ideas. Make sure you remove the two "hidden" bolts on the rear passenger's side (where the interior spare tire mounts) Unscrew all the bolts then remove the aluminum trimming that runs down the interior side edge of the top. You should be able to see the two hidden bolts. After that the top should be able to come right off. Make sure you have a couple of friends around... unless you can shoulder press 300lbs.!! good luck and hope it doesn't rain.</font color=blue>
    BLAZE IT UP!!!
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Dont forget about the wires for the rear dome light, too. They are on the drivers side.
