Golf Balls vs BB's
Discussion in 'The Garage' started by 78 k5, Sep 6, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    39.5 IROKS, should I go 10oz of BB's or 7 golf balls?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would go with 12-14 oz of BBs.
    Air-soft BBs that is.
    See here.
    Ira
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    air soft are the way to go. Better distribution. I put them in my DD and they work great. :D
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I bought airsoft pellets on ebay, yet to put them in because I have stupid rubber valve stems and my tires need to be broken down, pop the bead and slap em in. Damn valve stems.
  5. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    {apposing veiwpoint} 5 golf balls work great in my 42" swampers. {apposing veiwpoint off} :wink1:
  6. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    ok i'll bite
    what does this accomplish?
  7. sandawgk5
    Oct 28, 2003
    6,881
    It is called dynamic balancing. Use place weight inside the tire that will distribute itself where needed to balance the tire and wheel assembly. It also never needs to be changed because it redistributes everytime the tire stops and starts rolling again. If you do rocks or woods when you wheel it can pull weights off of the wheel and then you are unbalanced. It also will counteract any lost lugs if that ever happens. By that I mean if you loose a lug of tread from the tire it will still balance.
    Ira
  8. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    :cool1: Learned something today. :bow:
  9. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I could see doing golf balls in larger tires. 12 oz of pellets is alot :eek1:
