gonna be picking up a car this weekend need advice
Discussion in 'The Garage' started by freeflow, Dec 11, 2006.
  1. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    Im gonna be buying my buddies 94 ford probe gt with a bad motor for $700 this weekend and i need to get it from his place to my place and thats about a 2 hour drive. Im just gonna rent a tow dolley for the day and go and pick it up, but i wanna know do u think my truck will make the trip ok??
    87 reg cab long bed 1/2 ton 350-700. The car weighs about 3 thousand im told so i dont think the truck would have a problem making the trip.
    what do you all think??
    Brad
  2. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    You sholdn't have a problem pulling it... just remember to tow it in D not OD. :D
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    have a friend with a 3/4 ton rent a trailer for you. A car trailer would be better if its a light one, you just cant' legally rent one with your truck.
    Either that, or get k20 badges for the trip to the uhaul store :)
  4. blazersnburban
    blazersnburban Registered Member
    Nov 30, 2006
    80
    tunica, MS
    really...uhaul won't rent those dollies unless you have a 3/4 ton or bigger? i've seen people around here drive off pulling them behind a bonneville!
  5. dhcomp
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    They won't rent you a trailer w/o a 3/4 ton for insurance reasons. I don't know about a dolly. I just said i'd reccomend a trailer.
  6. 64suburban
    64suburban Registered Member
    Feb 9, 2006
    57
    tn
    I have never heard that before, what will happen if he pulls it in OD, and is that the same for a stick shift? Would you pull it in 4th gear instead of OD?
    Also in TN Uhall won't let you have a car hauler unless you have a class three hitch.
  7. dhcomp
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    I hope the hitch on that blazer is class 3. I thought all the stock ones were class 3 or 5.
  8. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    If you tow in od you will put excess strain on the engine and wear it out faster same with using a/c. A manual im not sure on but as a rule of thumb always accelerate in the lowest possible gear without going too low. once you are cruising it can be sent into od or 5th.
  9. dhcomp
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    I think the deal with OD is the 1/2 ton trans often hunts between OD and D to maintain speed when towing. THis generates excess heat, and heat kills 700R4's....... With a 4l80e you are normally ok in OD unless towing really heavy stuff.
  10. krechj
    krechj Registered Member
    Nov 14, 2005
    33
    Murderapolis, mn
    when i use to race i'd rent huge heavy duty auto trailers and hauled it with my car on it with my 1/2 ton to the track and back fine. i towed my blazer on a trailer for a 3 hour trip with a 1/2 ton ford and that was fine. but my truck doesnt have any badges on it so maybe they didnt know it was half ton when renting me a trailer?
  11. krechj
    Nov 14, 2005
    33
    Murderapolis, mn
    and pretty sure your suppose to tow in D and not OD to save your tranny, the engine could care less really
  12. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    If it is the Probe with the Mazda engine, you may be paying too much. They are expensive little boogers. Look to pay out the nose at a junkyard for them. I had a buddy just give $250 for a '96 with a bad motor. It was a PINT to swap out the motor, and he had to look for a couple months to find a motor at a reasonable price (actually knew someone at a junkyard who was hard up). Unless the body is immaculate, and tranny is guaranteed, I say $700 is too pricey.
  13. 64suburban
    Feb 9, 2006
    57
    tn
    A class 3 hitch is like what they sell at Uhall or a drawtie, that bolts directly to your frame. If you just have your trailer ball sitting on your bumper they will turn you away, or at least just in my experience. I have rented one before and I have went with a friend to rent one on another occasion and he couldn’t rent one because he didn’t have a class three. When I rented a trailer before that I have a whole ton 3500 dodge, with a class 3.
    Here is drawtie’s site and a picture of a hitch, and yes I believe some trucks do come stock with one but they might of had a towing package or something, I’m not real sure.
    http://www.drawtite-hitches.com/site_index/towproduts2.htm
  14. dhcomp
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    Yah, thats what i meant. Didn't even remember teh bumper ball setup, as i ALWAYS think that is a joke.
  15. 90v1500
    Oct 1, 2004
    56
    Huntsville, AL
    Yeah, the pressure's too low in OD and the trans burns up...
  16. 64suburban
    Feb 9, 2006
    57
    tn
    So is that the number one reason for trans failure, heat? And what if you had a turbo350, since it dosn't have OD would it just be fine to go at it? Could you tow in OD if you have a trans cooler besides the factory one that's in the radiator if heat is the only problem? Just wondering.
  17. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    Dude... $700 for a Probe? With a bad motor?????? WHAT!
  18. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    I just picked up a 93' probe GT and rented a dolly to pull it home. I used my 90' TBI Blazer w/ 700R4, ext. tranny cooler and ext. tranny filter (adds a little more capacity to help keep things cool) and had no problems.
    This was from upstate NY to Mass and back (about 260 mi round trip). The Mass pike is all hills and I kept it in D @ 60MPH the whole way. Got passed by everybody!
    Just remember, if the probe is lower then stock you will be able to pull onto the dolly but you wont back it off without ripping the front clip off. The stock probe I picked up got hung up on the dolly ratchets and almost tore it up unloading it..........Also, I payed $400.00 for a fully functional GT. I wouldn't pay any more then $300.00 for a parts car.
    Good luck.
  19. 90v1500
    Oct 1, 2004
    56
    Huntsville, AL
    :D Heat if the main cause of failure in the 700r4 but even with a extra cooler it's not a good idea to towing OD with it. Towing in D is the same ratio as a TH350, 3rd gear in both is 1:1. Towing in D will keep the engine RPM's up and better fluid flow through the trans and help keep it cooler, but a extra cooler is always a good idea...
  20. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    700 do not tow in OD, or even a heavy load in the bed. The trans cannot handle it, the engine will be fine. Do you have a trans cooler? It would be good insurance, but if your only at 3000lbs should be ok without it, unless you get into a strong headwind or long hills, remember heat kills auto trannys.
