GONNA BLOW???
Discussion in 'The Garage' started by CHEVY 4WD, Oct 30, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Well its a 350 it dosent have a TON of miles but its not brand new either. Well im wondering if its gonna blow up because ill be crusing down the road at a even rpm and the eninge will start to cut out then go cut go cut go some times it will do it for a wile some times just a few times it also did it last time I went up a steep bridge. I looked at the oil pressure gauge when it happended to day and was fine but im not sure if it really works 100%. Any help would be appriciated. BTW I want to keep it a 350 I dont want to bore so what im I looking at for a rebuild? pistions and rings? anything else? I was told you can pull out the pistions though the bottom of the engine (after the oil pan removed)
    Also someone told me it could be a fuel pump???
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I dont want to sound like a dick /forums/images/graemlins/rolleyes.gif, but filling out your profile would help to answer questions like..
    Fuel Injected
    Year
    Location of Fuel Pump.
    If it is fuel injected, it could be a filter, or the pump.
    John
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Its a carb and i dono about the fuel pump and its a 85 truck
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> This is either a fuel delivery or an ignition problem. It sounds totally unrelated to the condition of the engine itself. </font color>
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Ignition as in? btw its got a HEI
    Also it dosent do it every day but it a daily driver and seems to do it in the seame stretch oh the road where there not a hole lot of traffic or any stoplights or intersections and you do 55-65 in that are but seem like when it happens im doen about 60.
    When you say fuel dilevery do you meen like a new fuel pump?
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I mean, either it's not getting enough fuel, it's getting too much fuel, or the spark is not consistent. I'd guess it's afuel problem though. It could be as simple as an out of tune carb, but with what you've posted I see no reason to suspect that the engine is on the way out. That is, unless it's surging because it's running really lean, then you could have toasted the engine... </font color>
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    how should i go about adjusting the carb its a quada jet does anyone think its the fuel pump though?
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    change the fuel filter too
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you don't know what you're doing, I would recomened having someone else do it for you. What part of FL are you in ???? I'm sure a CK5 member near you would be happy to show you how to tune it propperly.
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I just swapped a big block into my '76...Had a very smiliar problem afterwards.....At about 3200 RPM's it would kinda fall flat on it's face and stumple, surge ect....I didnt know it at the time but the feul pump from my small block wasn't compatable with the big block Actually read that in a buds Hollander Interchange manual. While I was at his place, I was also talkin to him about timing......Ended up pullin the cap and rotor off the distriutor, and found out that the advance springs were too light and not alowwing ANY advance. Put some stiffers springs in it and got a BB feul pmp..Now it runs like a raped ape. /forums/images/graemlins/smile.gif
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Im not a dummy at this ive messed around with 4wheeler carbs and am just not formiller with a quadrajet or anytype of truck carb and theres no one by me ive checked
  12. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It could be something really basic. i had some problems a while back that were caused by having a bad ground on the coil-truck would work ok, then not, then ok, etc. Took off the ditributor cap, noticed some corrosion on the ground wire, cleaned up and worked fine since, that was 2 years ago. I should replace the cap, and coil n stuff, just haven't got to it /forums/images/graemlins/crazy.gif
  13. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Could it be a vacume problem?
  14. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    sounds to me like it could be a dirty needle and seat maybe and its causin the bowls to stick and lettin in too much or too little fuel! try cleaning the carb
  15. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Could I do it with carb cleaner or take it off and take it apart?
