Gonna do a homemade shackle flip today.
Discussion in 'The Garage' started by MOABDADC22, Sep 2, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Like the title says, I am going to do a homemeade sahckle flip today. Any words of wisdom??
    I am going to use a torch to cut the rivets and to make a "rough cut in the hanger, then use a cut off wheel/grinder to clean up the hole.
    I should get 4" of lift right? Will the pinion need a shim now?
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    You could probably do it without removing the hanger from the truck...
    I cut the hole then trial fitted the shackle, made sure it had plenty of swing in either direction before re-assembling everything.
    I also added a couple of gusset plates on the top side for strength.
    You will gain 4" and you might have to shim the axle and or drop the T-case. IIRC we shimmed 4 degrees on my buddies truck and dropped the T-case 1" (or less...I'd have to have a look again)
    Grease the hell out of the shackle bolts when you put it back together, or get some greasable bolts and stuff. It really helps ride and flex.
    Rene
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yep, 4" of lift. As for shims for pinion angle, and I'll probably get hammered for telling you, I didn't use any. Dropped the t-case (208) 1" and went with it. Haven't had any problems in two years +.
    John
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Actually, you will only get 2-3" of lift with this flip.
    For example - I run 6" Skyjacker springs in the front. In the rear, I have 4" Superlift Springs (New) and 1" Zero rate and my truck sits level.
    As Rene said, no need to remove the hanger to do this mod. Use a Cutoff Wheel without the guard (be careful and wear leather gloves). I did this in about an hour - many moons ago!
    Also, use a welding blanket to keep sparks off your gas tank and filler tube. I also would run a box fan under the truck to keep the air circulated to keep Gas fumes from building up.
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I dunno Neil,
    On my buddy's 89 Blazer we installed 4" Pro-comps up front and did the home brew flip in the rear with stock springs. No zero rate and the truck sits level...maybe 1/4"-1/2" high in the rear. It definitely does not have any rear sag though.
    Even using the soft 57's I got 4" in the rear of my truck...
    Rene
  6. Mudzer
    3,639
    Missouri
    My Superlift springs were brand new when I installed them along with this flip. I think my Skyjacker front springs may be more than 6" for some reason. I just didn't want anyone to assume you get 4" and get less - Go Prepared!!! Saggy butt is a bad thing.
    Think of it this way - you typically get half of what your shackle difference is. Lets say, you have a 1" longer shackle than stock; you are moving the spring eye 1" lower than before and you gain roughly 1/2" of lift as a result. What is the existing length of a GM rear shackle? If it's 4" length and you flip it over - moving the spring eye 8" lower than it was, you gain roughly 4" of lift regardless of what your springs are doing.
    Oh and, some people do require about 2.5 degrees of angle shims added for this mod.
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i think that's the problem right there. the skyjackers tend to run taller.
    i know that my truck sat taller with the 8" skyjackers than my brother-in-laws truck when he installed an 8" superlift.
  8. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    Mudzer - your rear springs must be sagging or maybe it's the brand, because every single person who I have ever talked to that has done it (oh yea, and I did it too), got 4".
    When I redid my suspension, I put new stock springs in the rear with a 4" longer shackle (for lowering a '99-__ Silverado), and netted 6". I have 6" softrides in front, and the rear is a little bit higher, because I took the bed off, and I have yet to put the fuel cell, spare tire, toolbox, and flatbed on.
  9. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Thanks for all the replies and info /forums/images/graemlins/thumb.gif. I never got around to doing it today, so I will do it tomorrow.
  10. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Rusty,
    Could you post a picture of what the hole looks like from the bottom and/or top? I'm trying to see exactly how you did this. Looks like a cheaper solution to the shackle reversal kit. Not to mention not having to take out the gas tank in priceless. I've been waiting for $$ as I need to shackle reversal kits. I might just be ready for my upgrade not /forums/images/graemlins/grin.gif
