gonna get a 60 gonna get a 60!!!!!!!!!!!!!!!!
Discussion in 'The Garage' started by rubbinz raczn, Oct 11, 2004.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    bought i ton front-rear from laketex(thanks bryan) i have seen someone mention difference in lift height vs a dana44. do you gain 1 inch? also how about front driveline length, does the 60 have a longer section where the pinion is? /forums/images/graemlins/thinking.gif
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yes, you gain a little lift... not much. You will also either need to shorten the front driveline or push the front axle forward, like w/ 52's or zero rates or something.
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    The dana 60 gives aprox 3/4 of an inch of lift. The pinion does stick out a bit more. Depending on how much lift you have, you may or may not need mod the front driveshaft. I have 6 inch front springs and didn't do anything to my front shaft. Haven't had a problem with it yet anyways.
