Gonna replace my intake gasket
Discussion in 'The Garage' started by SummitXMK, Jul 3, 2002.
  1. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    I am going to replace my intake gasket on my 95 k1500 350. Are there any tricks or things I need to watch out for? It is the first time I have dived this far into an engine.
    Well I form fitted a head gasket on a Derby car once in between heats but I don't think that counts? /forums/images/icons/tongue.gif Is there a better type of gasket to get. Do I need to torque these or tighten them in a special order or is it mostly a bolt on process. What about rvt? Do I use any or not. This is something I would only like to do once. Anyway thanks for any help you can give me.
    SummitXMK
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    keep all rtv out of the motor.. use a shop vac to vaccume out the inside once open...
    Dont leave any tools inside... <--- do a search on this...
    Take your time and do it right.. no big deal!!!
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    A haynes manual would tell you the torque specs for the intake. I believe that you start tightening them down in the middle and work out to the ends of the motor in a circular pattern.
  4. SummitXMK
    Jun 6, 2001
    141
    Idaho
    which RVT would you use? Or would you be better off just not using any? I am assuming red RVT but ya never know. Thanks for the input.
    SummitXMK
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Do you have a vacuum leak, or an oil leak? Our '94 Sub was getting a puddle of oil on the top of the intake manifold. The 2 center bolts on each side thread into an oil passageway. I removed the bolts, cleaned them and then coated the threads with Permatex #2 and reinstalled them. Haven't seen a drop of oil since. /forums/images/icons/cool.gif
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Use Peramtex black RTV on the front and back of the block. Don't use those POS plastic gasket things that come with the intake gasket set. The intake bolts have to be torqued to a specific order for the 1st torque setting, then another specific order for the 2nd torque setting.
  7. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Thanks for the advice. Now off to the taks! /forums/images/icons/tongue.gif
