Gonna start my side panels this weekend and need help.
Discussion in 'Audio' started by MudFrog, Jan 31, 2002.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    First off I need to know what type of board I should use for my side panels. Plywood, that medium density fiber board? I need something strong and somewhat water proof. If I have to treat the wood that is fine, I just need to know the best / most inexpensive route.
    Secondly, where can I pick up some of the Felt cover? Do I need to go to the local audio place or does anyone else carry it?
    Thridly, what do I need to do to keep vibrations down? Right now I have a 10" sub and the vibes are pretty bad in the rear. I think that has to do with my top though.
    Anyone have any other suggestions to make the process smooth and easy? I'm open for any comments.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    on my side panels, I used 1/4" ply. Cut to fit. Then I used a sanding sealer...lots of coats to make sure it wouldnt rot away on me. Lastly, I spray painted the things and then covered them (hello staples) with simple vinyl from a fabric store. So far they have worked great for me. Pics on webshots...
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    get a piece of paneling, you know that stuff on the walls of trailers? you the back side out, and paint &amp; everything else sticks to it easily. pretty durable stuff, and easier to work with then wood.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    hey man,
    i used MDF board on mine. then i painted them w. oil paint, then i covered them w. poly urithane clear coat
    they are VERY water resistant, i wouldnt say water proof, but water doesnt mess them up!
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I used 3/8 inch wide ply wood for mine and painted them with duplicolor coating... worked good thus far!
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    "Grace is knowing when to be a lady and when to say "Ah, bite me, outta my way!"
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Ok for lightenss and Strength used Birch plywood. It is a dead ringning wood so rattles are rare. It is much lighter than particle baord and mdf. My second choice would be MDF. heavy but strong but you need to put some thompsons water seal on them as well Blazers back there sweat alot. Wood doesnt last long. P.S. Birch is expensive but worth it.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  7. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    How did you attach the panels to the truck, used the stock screw locations? I'd have thought with thicker material being used there may be problems. Do you have dimensions for your panels by any chance?
