Goo off
Discussion in 'The Body Shop' started by burban89, Apr 19, 2007.
  1. burban89
    burban89 1/2 ton status
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    I'm prepping to paint my Suburban. What is the easiest and quickest way to take off the goo that the pinstripe and molding leaves behind.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    lacquer thinner will cut the fastest... Well, Acetone will, but acetone sucks to use...
    or you can go milder with 3M adhesive cleaner, mineral spirits, WD-40, etc...
    But thinner will cut it better than anything...
  3. burban89
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    I tried the PB Blaster goo off stuff but it just seams to smear it everywhere. I have to pick up some Acetone or Lacquer thinner tomorrow. Thanks.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Well, it will do the smear thing with anything, it's just the lacquer thinner gets it dissolved the best...
    Any thin solvent will do, where it gets slower is when you go to thicker, not as potent solvents, like goo-off, adhesive remover, mineral spirits, etc
    much safer, but twice as slow...
    use plenty of fresh rags, don't wanna be rubbing all that glue back on... :wink1:
  5. burban89
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    I use to have this rubber wheel that was made for taking off pinstripe, but I cant find it and there aren't any good body shop supply stores around me.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Yup, there's quite a few versions of the rubber flapper wheels.... Some work ok.. I've always gone back to the old fashioned methods...
    I remember when they came out with those things back in the 80's, used em on pinstripes all the time... They work better at the vinyl, than the glue...
  7. burban89
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    The one I had was a solid orange wheel, it worked like an eraser. It worked great took off vinyl and glue, I used to take the pinstripe off my Acura.
