good 4:10 ring gear
Discussion in 'Parts & Trucks Wanted' started by chevyguybc, Nov 23, 2006.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    im looking for just a ring gear, a rock cracked my ring gear , stupid chrome diff covers
    anyways, if i have to buy a ring gear and pinon ill look for a complete diff.
    just seeing if a fellow ck5er has a 4:10 dana 44 ring gear lying around they want to ship to me
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You should change them out as a set
  3. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    yeha? is that recommended, never changed gears before, going to learn, bought a dial indicator, thought i could just swap the one..
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    It is best to change them out in sets when your dealing with used gears. They get a wear pattern once they are used and will fail pretty quick if you swap it out with another used/ mis-matched gear.
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    good to know. im only 21 and learning along the way.. thanks again..
  6. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I'm not a R&P expert, but it would seem to me that it would be less of an issue if it was the front since it's not running all the time.
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    did you ever find a set. I just listed a set on Ebay. I know they are good because they came out of my truck. I would sell them direct to you on here but they usually do decent money on there. check em out. Item number: 260060043872
