Good bearing grease?
Discussion in 'The Garage' started by toy4x4runner, Oct 6, 2005.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    I'm currently using red'n tacky from Lucas. What do you guys reccomend for a good wheel bearing grease? I've been thinking about using Lucas' Xduty grease.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I use Redline CV Joint Grease. I have not had any bearing issues since I started using it. I did have problems b4 with several different greases. The worst was with boat trailer wheel bearing grease.
  3. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    Kendall ultra blue or if its not ultra blue then its super blue, I always forget
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    My friend used wheel bearing for trailer on his ramcharger and it overheated and the inner wheelbearing got so hot it seized onto the spindle. He had to take a grinder and go right through the hub. So lesson learned, used grease that is made for disc/drum brake use!
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I use Mobil 1 synthetic grease for everything.. Trucks, cars, trailers. Works great for me.
    John
  6. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    The grease praised by the porsche club down in SA is made by swepco. I used it on my old 944 CV's, wheel bearings, pretty much anything needing lube. It is great stuff. A friend from the Porsche club drives 18-wheelers and races a 911 in the SCCA. He swears by swepco lube and motor oil, which he purchases for his big rig and for his race cars. I don't know if any of the vendors sell it, but the place I used to buy it is called Paragon Products.
    http://www.paragon-products.com/product_p/swepco101.htm
  7. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i use castrol's grease, its pecuilar because it has a minty smell to it.
  8. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I have a weirdo german can of lube (i think it's a gallon of it) -- my friend gave me it, no idea what it's called since it's written in german. but it's high temp, and never comes off of anything. I don't know if that's good or bad, but i've never had problems with it. I'll try to get the name of it later on.
