Good bye Double Cardan CV- Hello Cornay Joint??
Discussion in 'The Garage' started by Brian 89KBlazer, Feb 12, 2003.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I know it's old but a quick search didn't turn up anything in the past month. P. 94 of March/2003 Petersen's, there's a new Cornay joint which is supposed to be stronger & smoother than a CV joint & able to handle higher loads at 90 degrees! /forums/images/graemlins/thumb.gif
    It also says it has been used in Baja for years. Anyone in the driveline industry care to comment? Is this the ultimate CV or are we not getting the whole story? /forums/images/graemlins/ooo.gif
    I haven't gotten to the point of ordering my High Angle Shafts yet so maybe this could be the new way to go?
    Here's a link: http://www.drivetechnologies.com/
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    To me it looks like a CV thats longer in the yokes w/ rings around it to help strengthen it. Maybe Im just overlooking something. It should hit better angles though.
  3. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    there apparently kinda pricy- on average 700-1200 $ just for the c/v alone- but maybe in the future they will be less- Jesse
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Looks like they turned a regular u-joint inside out...
    That ring is what transmits the torque and not a cross style u-joint.
    Interesting?
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Looks like a good idea. I actualy saw a real neat idea on a rockcrawler this past weekend. He use a toyota birfield as his joit for the front axle. He has having problems with the andgles his is running. It was on a 4runner with a solid front axle swap. The birfield eliminated him breaking the shaft. His test shaft was a two pieces of box steel that slid into each other, and it didnt even vibrate or bind.
    Dan /forums/images/graemlins/burb.gif
  6. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Jesse & everyone
    I figured there had to be a catch & the minute Baja racing comes in, I guess I should have known the price for the joint would be more than the price of a driveshaft! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    If you are only running 5.5" of lift why would you need a driveshaft that is capable of 90+ degrees?
  8. Brian 89KBlazer
    779
    Ontario, Canada
    In reply to:
    ........Cause I have a custom built chassis that gives me another 4-5 inches of lift over a stock frame, I have D60 & 14ff, a shackle flip set-up in the rear, & I have the drivetrain tucked up into the frame as high as I can & would like to keep it there above the bottom of the frame rails if at all possible!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Sounds cool. Do you have any pictures of that?
  10. Brian 89KBlazer
    779
    Ontario, Canada
    Poohbair
    Yes & No! /forums/images/graemlins/rolleyes.gif
    I do have some photos of the first stages of the frame construction (which are not scanned in yet) & a couple of not so good ones of it with the Blazer assembled on it. Unfortunately, my Blazer had to get thrown back together last spring to go into storage /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif & I'm only now trying to get back at it to get it finished. I'm starting to strip the body apart again to get the frame finished & then POR15'ed.
    That may not be until spring when the weather warms up but I'll try to get some pics of it when I disassemble it again.
  11. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I didnt realize you had that much lift. I looked at your profile and just seen the 5.5 bds, and thought heck you dont need 90+ for a 5.5.
  12. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Hey Brian buddy! Where's the pics?? /forums/images/graemlins/thumb.gif
