Good cam and carb choice?
Discussion in 'The Garage' started by jess, Mar 18, 2004.
  1. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    I'm "freshening" my 78 4 bolt for my K5. I'll be running a 465 with 5.13s and probably 39.5s. Engine will be mild with around 9:1 compression. Thinking of going with the Edelbrock Performer intake and matched cam kit for good driveability. Anyone running this package or have another idea for a cam? Also looking at running a matched Q-jet from Jet perhaps or Holley's Truck Avenger. Any thoughts or experiences? I wanna do it right the first time. /forums/images/graemlins/hack.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you're wanting to do it right, avoid the Edelbrock cam like the plague.
    Since the engine is going to be mild, I would definitely suggest something EFI friendly, and that you not waste $400 on a Qjet when you can get a TBI arrangement and go EFI for about that price or not much more.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I wouldn't use the edel. cam. It is very small compared to some of the smog legal cams that comp makes.
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That grind is a stock replacement cam and if you are gonna be going through the trouble of a cam swap you may as well upgrade.
    What heads are you using?
    The performer intake is a good stock replacement that can handle a mild cam. Comp Cams 4x4 line has a few good choices.
    It kinda all depends on what you want the engine to do.
    I just bought a Rhoads Hydra-solid cam. With the heads, intake and carb I have it ought to be one nasty sucker.
    I'm just waitin on a few more goodies to show up so I can slam it all together. /forums/images/graemlins/woot.gif
  5. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Edlebrock Performer (Not RPM) intake $115
    Summit Racing Headers $89
    Summit Cam 214 224 duration $100
    600 cfm carb.
    You will add some major torque to your truck /forums/images/graemlins/waytogo.gif
  6. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Good choice, sorta the same one I was debating.
    With the exception of a Q-jet.
    The only reason I am using a 750 Ebrock carb is that is what I have to work with at this time.
    I'll run that set up till I can get ahold of an Ebrock RPM intake and rebuild one of the 454 Q-jets I have.
