good cam for tbi motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 3car, Jan 15, 2002.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    im getting ready to put a motor together for my truck.i using a stock gm shortblock ,factory tbi,and vortec heads.i need a cam that will take advantage of these heads and a free flowing exhaust,but not freak out the computer.thanks...
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    come on guys.....
  3. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I'm using the Edelbrock 3702 in my rebuild .. a little warmer than stock but not enough to mess with the 'puter. doesnt do much after about 5500 rpm but it builds good torque off idle to about 3500-4000
    Scot in KC, MO
    87 GMC - 4", 33s, 3.73 10B/14SF
    http://community.webshots.com/user/sdb95
  4. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    thanks
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    From what I understand you can get away with anything up to about .440 lift on the TBI computer gigs. The main thing (also from what I've been told) that the lobe seperation is key with computers and cams. Something like 112 lobe sep is supposed to be right on the money, but again this is from what I've gathered from around here. I too am building the same setup. I've only gotten as far as getting the block back from the shop and painting it......Damn I wish this money tree would grow faster!! [​IMG]
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Call up your cam manufacture of choice and ask the tech line., That is gonna be your best advice. You are basically SOL with the stupid TBI ecm since it is speed density... You can however look into a MAP adjuster from Turbociy or talk to a chip burner about what they can trick the eem into with a new custom chip. I have been scouting for one also and haven't had much luck at all finding one that satisfys me.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK here are the cam's I've selected; crane cam # 114122 - this is in JMT and needs to be advanced 5 deg. at install. this cam is going in IE on the current rebuild; 12-249-4 comp cam.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
